                                2014/03/13 13:55 GMT-4
Turns out you don't need the PDE module!!  Just type ' 1+(100-1)*(1+(1*spf.sr)^2)^-0.25 ' in for mu under the fluid properties node.  I would suggest using parameters for mu_inf, mu_0, lambda, and N but it is up to you.
See attached file, I would suggest doing a power law model first and compare to the analytical solution to make sure everything is working as expected.
Good luck!
Edit:  I should add spf.sr is the variable name COMSOL uses for the shear rate in most fluid flow applications.  If you are doing Fluid Structure Interaction you have to use fsi.sr (I think).  you can always check variable names using equation view.
-- Alex
Good luck!
-- Alex
                                2014/03/18 5:07 GMT-4
                                                    Hello Alex,
Thanks for answering! I appreciate your suggestion and also I think it's helpful to know what you wrote on the second part of your post about the shear rate "spf.sr", it might be useful for me later.
Thanks a lot,
Daniel
                            Hello Alex,
Thanks a lot,
Daniel
                                2014/06/17 10:03 GMT-4
Good luck!
-- Alex
Could you explain a little bit more about spf.sr and fsi.sr?  I'm trying to make a model using a carreau fluid but I don't have the package so I'm inputting it manually.  For some reason spf.sr isn't in my equation view (I'm using version 4.3)
                            [QUOTE]
Good luck!
-- Alex
[/QUOTE]
                                2014/06/18 16:43 GMT-4
                                                    spf.sr and fsi.sr are the variable names for shear rate in two different modules.  I'm not sure which module you're using or what the shear rate is called.  I would recommend solving any problem in the module of interest.  After you have a solution plot the shear rate.  When you plot the shear rate, the variable name is entered into the box "Expression" on your plot (line graph for example).  That expression is the variable name for the shear rate, it's what you need as the independent variable in your carreau model.
Good Luck -- Alex
Good Luck -- Alex
