Help : Iterative variable : n1 = n1 + 125
How i can use an iterative variable for example n1 = n1 +125 in comsol
thank's
5 Replies Last Post 2014/06/10 15:34 JST
Posted: 1 decade ago 2014/05/18 2:26 JST
What would the iteration index be?
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
What would the iteration index be? Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 2014/06/07 22:05 JST
No body can answer me !!!!
How i can put : var = var + 125 in comsol
comsol give me : Circular variable dependency detected
Please ho can answer me and give me solution for : var = var + 125
Mr Ivar Kjelberg were are you ? give me solution !!
No body can answer me !!!! How i can put : var = var + 125 in comsol comsol give me : Circular variable dependency detected Please ho can answer me and give me solution for : var = var + 125 Mr Ivar Kjelberg were are you ? give me solution !!
Posted: 1 decade ago 2014/06/07 23:43 JST
Well, I try once more despite you didn't tell me with regard to what you want to iterate. If it is about non-linear solver steps you could try:
var = 125*niterCMP
I don't know if it works, just try it. If your iteration index is something else you can try to find it in the documentation.
var = var + 125 is not a valid equation. It reduces to 0 = 125 which is obviously wrong.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Well, I try once more despite you didn't tell me with regard to what you want to iterate. If it is about non-linear solver steps you could try: var = 125*niterCMP I don't know if it works, just try it. If your iteration index is something else you can try to find it in the documentation. var = var + 125 is not a valid equation. It reduces to 0 = 125 which is obviously wrong. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 2014/06/09 1:08 JST
Thank you Edgar J. Kaiser for response
The equation : var = var + 125 : The new value in the present step of "var" = the previous value in the previous step of "var" + 125 .
Thank you Edgar J. Kaiser for response The equation : var = var + 125 : The new value in the present step of "var" = the previous value in the previous step of "var" + 125 .
Posted: 1 decade ago 2014/06/10 15:34 JST
Where 'step' means time step I suppose? It would be a bit strange in my opinion to formulate your model like that, because the rate of change of n1 with time would depend on your time step. Rather I would include something like d n1/d t = 125.
