High Mach Number Flow, weird things for inlet settings when imposing the total/static conditions
Posted 2014/08/01 11:50 GMT-4 Computational Fluid Dynamics (CFD) Version 5.2 1 Reply
As the title state, something weird is happening I think. I am simulating a coaxial jet, 2D axyalsymmetric, surrounded by slow moving air (M = 0.01), with the external flow being chocked.
I imposed the following TOTAL inlet condition in the external flow, characteristics based:
p0 = 246465
T = 293.15
M = 0.1 (don't know why it should be needed...)
After many simulations converged (unfortunately), I realized there was something wrong checking the mass flow through the chocked nozzle, significantly different from the theoretical one (and by the way, I found also the mass flow slightly decreasing from the inlet to the throat O.o!).
Then I checked the pressure in the results, at the inlet, and I found those values:
p=p0= 284000
T = 303
M = 0.01
Completely wrong! Now, for trying, I put the same values, with STATIC, and all was exactly the same.
Then I tried both STATIC and TOTAL with M = 0.01, and the pressure at the inlet was correct.
Useless to say, I checked and re-checked everything. Gamma was ok, 1.4.
Something strange is happening here... Any clues?
Thank you
Hello Daniel Guariglia
