2014/08/26 6:52 GMT-4
Hi Eva,
Sure it is possible, see the attached example.
Best Regards,
Dima.
Dima Apter
www.a2z-consulting.com
Hi Eva,
Best Regards,
Dima.
Dima Apter
2014/08/26 7:05 GMT-4
Thank you Dima,
unfortunately, I know it should be possible. But I cannot seem to select a point when I want to add it to the array. I can only select domains (it seems). Do you need a specific module or something?
Thank you Dima,
2014/08/26 7:09 GMT-4
No, it shouldn't be a problem. Did you try to select using the "Selection list" window?
You can upload your model, i will take a look.
Dima Apter
Dima Apter
2014/08/26 7:15 GMT-4
Dear Dima,
Thank you! That did the trick. Strange that it cannot be selected via the graphics window. Normally this isn't a problem. Either way, this helps! Thanks again
Dear Dima,
