meshing - a boundary with points on it
Dear all
I am trying to mesh a 3D object. The object is not symmetric as a whole and it consist of thick and thin parts ( layers) . I tried to mange it by using free mesh parameters for a surface and then use swept one. But in my structural mechanics application I need to apply point loads and I put some points on the upper surface of the object. I can't mesh it using as I did before ( the swept + free boundary Meshes). Any Idea you have how to mesh object with points on the surface( boundary)?
best regards.
3 Replies Last Post 2010/04/20 4:44 GMT-4
Posted: 2 decades ago 2010/04/20 1:42 GMT-4
if you have only one surface with extra points, start by meshing that one, and then sweep from that surface. There are some topological limitations on the surfaces and their subdivisions in the direction you sweep,
Another way is to add the same points or cuts on all surfaces through the model, a few interiour boundaries does not overload a model
Have fun Comsoling
Hi if you have only one surface with extra points, start by meshing that one, and then sweep from that surface. There are some topological limitations on the surfaces and their subdivisions in the direction you sweep, Another way is to add the same points or cuts on all surfaces through the model, a few interiour boundaries does not overload a model Have fun Comsoling Ivar
Posted: 2 decades ago 2010/04/20 4:39 GMT-4
Dear Ivar,
Thank you for your replay. My object to be meshed is three layers of cylinder with the lower surface consists of small sized extra cylinder projections. I want to put some points on the upper surface. Without points on the upper surface I can mesh it successfully. But when I add the points on the upper surface it says topological error. even I tried to mesh the points at first.
with best regards.
Dear Ivar, Thank you for your replay. My object to be meshed is three layers of cylinder with the lower surface consists of small sized extra cylinder projections. I want to put some points on the upper surface. Without points on the upper surface I can mesh it successfully. But when I add the points on the upper surface it says topological error. even I tried to mesh the points at first. with best regards.
Posted: 2 decades ago 2010/04/20 4:44 GMT-4
Dear Ivar,
with best regards.
