Model the flow of a visco-elastic material
I'm currently working on a model and i can't seem to tackle a few problems. If you would be so kind to help me out, I would be entirely grateful.
The model is a 2D section of the real 3D problem. There are 2 solid plates (rectangles). Between those 2 plates i have a visco-elastic material (also a rectangular shape) with in the center a rectangular gap. A pressure (10 bar) is put on the plates (top and bottem). Because of the pressure, the plates will practice a pressure on the visco-elastic material which cause it to flow to the gap.
I tried the following physics:
1) Fluid structure interaction : Used a moving mesh to let the fluid move inside the gap. I used a presdiscribed displacement in the form of U_fluid * time (time is defined). I get an error: failed to evaluate variable U_fluid.
2) Solid mechanics in combination with moving mesh and laminar flow: I used this as an alternative but I can't seem to define contact between the solid plates and the fluid.
3) Maybe I could define a visco-elastic material under the solid mechanics module. The only problem that I then have is that I can't seem to define flow.
Thanks in advance
2 Replies Last Post 2014/10/24 16:18 JST
Posted: 1 decade ago 2014/10/24 7:47 JST
Hi Robin,
Interesting problem, though I can’t fully visualize it. If the viscoelastic material deformation is not that big then option #3 would be suitable. In this case you don’t explicitly define “flow”. The viscoelastic material will just deform under a constant load.
Nagi Elabbasi
Veryst Engineering
Hi Robin, Interesting problem, though I can’t fully visualize it. If the viscoelastic material deformation is not that big then option #3 would be suitable. In this case you don’t explicitly define “flow”. The viscoelastic material will just deform under a constant load. Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 2014/10/24 16:18 JST
Thank you for your reply sir. I managed to get things working with fluid structure interaction. The problem was in fact a convergence problem. If I ramped up the pressure on the plate, I did get the results.
However I still have some questions left. If you or someone else would be so kind to answer them.
In your reply, you stated that you can model the deformation of a visco-elastic material and not the flow if the deformation is not large. However the deformations in this problem are large (up to 50%). From experimental results I also get a laminar profile. I don't see how the solid mechanics module could simulate a laminar profile (in terms of deformation).
Is it possible to get the same results if you work with the fluid-structure interaction or couple laminar flow with solid mechanics and moving mesh.
When I model the deformation of a plate in 3D or the same deformation of a section of this plate in 2D. I got totally different results. In my opinion I should get exactly the same results. How is it possible that I get a deformation in 3D that is 1000x less than the model in 2D.
Thanks in advance
RG
Hello, Thank you for your reply sir. I managed to get things working with fluid structure interaction. The problem was in fact a convergence problem. If I ramped up the pressure on the plate, I did get the results. However I still have some questions left. If you or someone else would be so kind to answer them. In your reply, you stated that you can model the deformation of a visco-elastic material and not the flow if the deformation is not large. However the deformations in this problem are large (up to 50%). From experimental results I also get a laminar profile. I don't see how the solid mechanics module could simulate a laminar profile (in terms of deformation). Is it possible to get the same results if you work with the fluid-structure interaction or couple laminar flow with solid mechanics and moving mesh. When I model the deformation of a plate in 3D or the same deformation of a section of this plate in 2D. I got totally different results. In my opinion I should get exactly the same results. How is it possible that I get a deformation in 3D that is 1000x less than the model in 2D. Thanks in advance RG
