Add air box to a complex geometry via LiveLink for SolidWorks
Posted 2014/10/31 13:50 GMT-4 Low-Frequency Electromagnetics, Interfacing, Geometry Version 4.4 9 Replies
According to LiveLink for SolidWorks Users Guide, the geometry sequence can only contain the LiveLink for SolidWorks, however, one needs to add an additional air box for some physics interfaces, i.e., calculation of the magnetic fields in a computer case. Is it possible to add an air box while keeping the original SolidWorks model? Thanks in advance?
Tony
Tony
If you did that, then go find the error message and the associated boundary and manually mesh those within the physics generated mesh.
The reason that I need an assembly is that I get the model from others and it contains plenty of parts. Parameter studies on geometry is required, that's why I need LiveLinks. Yes, I did not select the "Merge results" option while intersecting, but there still is the mesh error in COMSOL. I will check what's the problem. Thank you for your help anyway.
Tony
I faced a same problem as I add an air box then it comes an error 'Intersecting face elements',
I meshed the domain by domain, and I make it extremely finer meshing the air box but it still failed.
Could u show me some details about the solution about it?
Thank you
Mathew
Suggested Content
- KNOWLEDGE BASE Error: Internal Error in Geometry Decomposition
- FORUM Air Box
- BLOG How to Analyze Your SOLIDWORKS® Designs with an App
- KNOWLEDGE BASE Error: Failed to Connect to SOLIDWORKS
- FORUM Problem Creating the "Air box"
