Fluid Flow in a Tube around a radially growing/shrinking cylinder
Posted 2015/02/04 2:50 GMT-5 Fluid & Heat, Chemical Reaction Engineering, Geometry, Mesh Version 4.3 2 Replies
Good Morning,
I guess I have a rather simple problem, but am not sure wether or not I am able to implement it at all and how exactly to do it. So I present you the problem and my solution afterwards.
I have a cylinder of diameter 10mm in a tube of diameter .2 and 1m length, the cylinder is placed at .5m/.1m. A fluid is flowing through the tube around the cylinder. For some reason the cylinder grows or shrinks with time at a defined velocity and I want to know how that influences the flow field. Over the cylinder boundary there is also mass transfer of a tracer substance that helps me to understand the influence of cylinder growth or shrinkage on mass transfer.
Now my idea is to define (in 2D) my geometry, which I did. Also the flow is laminar so I use the Single Phase-Fluid-Flow Physics. For the tracer transport I use the appropriate Physics for Transport of Diluted Species. The growth of the cylinder I implement via the Deformed Mesh Node and first define a constant normal velocity (for simplicity) on the cylinder boundary. When the cylinder grows the surronding fluid adjacent to the wall must have the velocity of the wall, so I use a moving wall boundary condition on the cylinders surface. Here is a problem in my eyes. I can define a moving wall in the fluid flow node, but must specify a velocity. I would expect, that somehow the deformed mesh speed and this boundary should be connected in some way, but they are not, and I cannot do it manually by entering the speed of the deformed mesh on the boundary.
Is there a mistake in my idea? Did I forget something or need to do something differently? Any help is greatly appreciated.
André
André
2 Replies Last Post 2015/08/20 0:41 GMT-4
