Changing units for plots in Version 4
In COMSOL 3.5, one could specify a different unit for plotting results in place of the default SI units. In 4.0, the units are in a non-editable drop-down box and cannot be altered. Is there a way to change the units for plotting?
Steve Conrad
1 Reply Last Post 2010/06/16 14:52 JST
Posted: 2 decades ago 2010/06/16 14:52 JST
No, not from my knowledge, your are somewhat limited still in V4, but you can always multiply the value or use a unit normaliser, i.e. a spring constant in K [N/m] can be redifined (as a unitless value) as K[1/(N/mm)]
Hi No, not from my knowledge, your are somewhat limited still in V4, but you can always multiply the value or use a unit normaliser, i.e. a spring constant in K [N/m] can be redifined (as a unitless value) as K[1/(N/mm)] Good luck Ivar
