Robert Koslover
        Certified Consultant
                                2 decades ago
                                2010/08/19 23:18 GMT-4
                                                    I'll take a guess.  When a problem includes regions that are both large and small (detailed), the default mesh settings are sometimes inadequate to handle it.  I recommend you set up some interior boundaries (without boundary conditions, which should default to continuous conditions) and then define the fineness of the mesh independently in the small and large regions.  Alternatively, once you have divided it up as I said, you can mesh the problem on a per-domain basis, in which case you may find it advantageous to mesh the finer domains *before* you mesh the coarser adjoining ones.  That makes it easier for the meshing routine to figure out where to insert mesh points.
                                2011/03/29 4:55 GMT-4
                                                    Hi Robert,
I also have the same with meshing of the airgap in an induction machine. Can you explain this solution more clearly?
Thank you
                            Hi Robert,
Thank you
                                2011/03/29 15:33 GMT-4
I have noticed often issues when a geometry contains multiple loops, in these cases its often useful to add some interiour boundaries, and mesh "by parts/sections" manually
