Fluid Flow through a Loop Reactor
Posted 2015/06/17 7:28 JST Fluid & Heat Version 5.1 0 Replies
I just started using Comsol for a few weeks.
Currently, I am trying to simulate fluid flow through a Loop Reactor that I designed in inventor.
Then, since I imported it to Comsol, I used cap faces to build the mesh for the volume. However, I want to define some conditions inside the reactor, basically I want to increase the velocity inside the loop (for example, using a pump) having low flow rates for inlet and outlet.
Is it possible to create another condition to change the velocity instead of only inlet and outlet?
Thank you for your help
Hello Joao Carlos Silva Lira
