Hello Albert Chen
2011/01/06 11:24 GMT-5
Albert,
My understanding is that the eigenfrequency calculation is for unloaded model. I suppose that in this case the voltage would be considered a load rather than a BC.....
My guess would be that you can get around this by running a frequency response around the values that come out of the eigenvalue problem at the various voltages...
Albert,
2011/01/07 1:35 GMT-5
Indeed what Physical phenomena should change the Eigenfrequency of a beam if you apply a voltage ?
f[Hz]= 1/2*pi*sqrt(K[N/m]/m[kg])
Probably you expected a stress stiffening via "K" or somewhat like that ?
then you must use Matlab and v3.5a or just COMSOL v4 (if possible 4.1 while 4.0 is rather limited and far more difficult to tweak in the solver section, it's was a too-early version)
for that
a) you apply your voltage in a stationary case to stress your beam,
b) you store the solution, and
c) you do an eigenfrequency analysis taking the stored solution as linearizion point
for that
2014/04/17 12:39 GMT-4
Hello Ivar,
I've been trying to figure out how to get a voltage vs. freq, initially I performed a study for the eigenfrequencies but I can't seem to get results computing power vs. freq or voltage vs. freq
[A bit of context]
I am designing piezoelectric energy harvesters with different geometric dimensions, shapes and materials, but in order to compare their feasibility to other research I need values for their power or voltage versus frequencies of 60-120 Hz
[Method so far in COMSOL]
1. Pzd > Eigenfrequency > created geometry, mesh and selected materials > added Electric Potential and Ground > after computing it I then stop here , because even though I've seen tutorials on how to create plots, I'm not getting the desired results
2. Pzd > Stationary > created geometry, mesh and selected materials > added Electric Potential and Ground > stopped here as well.
Your advice would be very helpful.
Yours Sincerely,
Cindy
Hello Ivar,
[A bit of context]
Yours Sincerely,
Cindy
