Hello Mark Roy
2010/11/22 7:37 GMT-5
did you get it?
did you get it?
2010/11/22 15:21 GMT-5
when you have several solutions (parametric sweep ,eigenfrequency, time dependent, then you must use the "solnum" to access them in order, check also the with() and at() operators (or whatever they are now clled in V4.
Sorry cannot tell more, I havent really had time to use Livelink yet, the new features of V4 have allowed me so long to survive well without matlab ;)
2010/11/22 19:48 GMT-5
After setting up and running an eigenfrequency simulation, I figured out that you can use mpheval to get the value from the dataset.
ie:
model.sol.create('sol2');
... setup solution features for eigenfrequency, number of steps, tolerance, etc...
model.sol('sol2').attach('std2');
model.result.create('pg2', 2);
model.result('pg2').set('data', 'dset2');
model.result('pg2').feature.create('surf1','Surface');
model.sol('sol2').runAll;
model.result('pg2').run;
eval = mpheval(model,'smpn.freq','Dataset','dset2','edim',0,selection',1);
eigenfreq = eval.d1;
Thats basically what I've done and it seems to work. The reason everything is number 2 is because I also have another solution for steady state response.
Hope that helps.
ie:
Hope that helps.
2015/04/03 23:10 GMT-4
I'm facing a similar problem: I'm performing a simple eigenfrequency study of a cable, repeating it for several values of a particular parameter involved. I do this by programing a loop in Matlab Livelink.
I'am interested in the first three eigenfrquencies, so I need to store them for each value of the parameter simulated. I couldn't manage to get those values into Matlab.
I would really appreciate your help.
Thank you in advance.
Bruno.
Bruno.
