Step Function
Hi:
I want to multiply a voltage source from the electrical interface by a step function to cause a delay, how to go about
that?
4 Replies Last Post 2017/05/31 23:24 JST
Posted: 1 decade ago 2010/09/02 6:46 JST
if I understand correctly your demand, I would propose to use the step function in V4 or a Heaviside (check the command.pdf doc) in V3.5 (they are the same in both versions, but they have been further implemented as clickable items in V4)
And then multiply your voltage amplitude by the step function, including a starting point (t-tau) and a rise time "DT" directly in the field where you need to define the voltage. (this applies to any variable by the way, not only to voltages)
Hi if I understand correctly your demand, I would propose to use the step function in V4 or a Heaviside (check the command.pdf doc) in V3.5 (they are the same in both versions, but they have been further implemented as clickable items in V4) And then multiply your voltage amplitude by the step function, including a starting point (t-tau) and a rise time "DT" directly in the field where you need to define the voltage. (this applies to any variable by the way, not only to voltages) -- Good luck Ivar
Posted: 1 decade ago 2015/04/11 0:43 JST
hi Ivar .. i want to apply lightning impulse voltage of 1.2/50 micro-sec to an electrode under electrostatics module ..plz suggest
Posted: 1 decade ago 2015/04/20 4:51 JST
Can you define it using ":?"? For example,
(t > 3) ? 1 : 0
would be a step going from 0 to 1 starting @ t = 3.
Can you define it using ":?"? For example, (t > 3) ? 1 : 0 would be a step going from 0 to 1 starting @ t = 3.
Posted: 8 years ago 2017/05/31 23:24 JST
Have you solve the problem?
[QUOTE] hi Ivar .. i want to apply lightning impulse voltage of 1.2/50 micro-sec to an electrode under electrostatics module ..plz suggest [/QUOTE] Have you solve the problem?
