Walter Frei
COMSOL Employee
10 years ago
2015/10/06 9:23 GMT-4
You may want to look at this material, it may point you towards an alternative approach to what you are attempting:
http://www.comsol.com/blogs/implementing-a-thermostat-with-the-events-interface/
http://www.comsol.com/blogs/using-the-previous-solution-operator-in-transient-modeling/
http://www.comsol.com/blogs/tracking-material-damage-with-the-previous-solution-operator/
10 years ago
2015/10/06 9:45 GMT-4
Alright thanks :)
Alright thanks :)
10 years ago
2015/10/07 0:49 GMT-4
If I want to apply a specific ODE in the region with temperature < 272K, like du/dt = F, but in other region where T>272, I wish to implement another ODE, du/dt=0. This means that depending on the temperature in that particular region, the ODE will switch. Can this be done in comsol?
Gunnar Andersson
COMSOL Employee
10 years ago
2015/10/07 4:50 GMT-4
Use the following expression in the Source Term in the Distributed ODE node: ut-if(T<272,F,0)
