Hello Victor Garcia
2011/09/14 8:41 GMT-4
Hi Victor,
I would be extremely interested to learn if you ever found a solution to this problem as I'm dealing with a similiar sounding problem of acoustic loss which I've currently attributed to viscous drag within a narrow pipe.
Regards
Alasdair
Hi Victor,
Regards
Alasdair
2011/09/15 6:42 GMT-4
Hi Alasdair,
I found two ways to solve the problem:
- To introduce the Navier-Stokes equation through its weak form.
- You can add an elastic domain whose Bulk modulus, density and Poisson coefficient are calculated in such a manner that the elastic equation matches with Navier-Stokes equation.
However it is remarkable that Comsol 4.2 has already added thermo-acoustic propagation, so it is the simplest way to simulate your problem.
Victor M.
Hi Alasdair,
Victor M.
2011/09/27 6:39 GMT-4
Hi Victor,
Would you mind sharing a simple example model with me, what you were doing sounds similiar to what I wish to achieve (modelling the viscous attenuation of sound waves through very narrow slits to observe the affect on standing wave resonances). I'm having trouble with the thermo-acoustic model solving and the sole example I have found on the website isn't a great help.
Regards
Alasdair
Hi Victor,
Regards
Alasdair
2011/09/27 11:08 GMT-4
Hi Alasdair,
At the moment I haven't had time to use the special features of Comsol 4.2 in this way, although I hope to do this soon.
On the other hand, regarding to Comsol 3.5, I send you a file that test the transmission through a layer of "air" modelled by using a elastic subdomain whose parameters (Young modulus and Poisson ratio) are defined in such a manner that the elasticity equation becomes Navier-Stokes. Note that the incident wave crosses the elastic subdomain without being altered because the viscosity of air is very low.
It is very important to mesh accurately the boundaries between elastic and fluid domains. Otherwise the coupling between these domains will be too poor. Take it into account in your problem.
Regads,
Victor
Hi Alasdair,
Regads,
Victor
