10 years ago
2015/11/12 16:29 JST
comp1.emi.disp is the displacement (sqrt(u^2+v^2+w^2)) of the Component comp1 (the first default model) of "emi" phyiscs Electromechanics from MEMS module. If you are in 2D w=0 and in 1D both v&w are =0, and in 2D-axi v=0.
But if your domain "1" is included in the EMI physics then "disp" should be defined. However, I suspect that you are plotting a complex geometry where only part of it is using EMI then "disp" is not defined everywhere. You must then restrict your Plot or Derived Value or Definition Variable to the domains where EMI is applicable
10 years ago
2015/11/25 16:15 JST
sir
thank you for your valuable reply. Here i am attaching my model. i couldnt follow your suggestion. i Humbly request you to help me for solving this issue
sir
Henrik Sönnerlind
COMSOL Employee
10 years ago
2015/11/25 18:41 JST
Since none of the domains has the 'Linear Elastic Dielectric' material model, there are no displacement degrees of freedom in your model. All domains are purely electrical.
Henrik
Henrik
10 years ago
2015/12/02 14:56 JST
Thank you sir for your reply.I got the displacement.
