Multiphyscis two-step analysis
Posted 2016/01/18 6:59 GMT-5 Low-Frequency Electromagnetics, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Studies & Solvers Version 5.1 1 Reply
I have four models - Electric EC, Magnetic-MF, Heat Transfer-HT, Laminar-SPF.
In Study-1 I solve for only the first three and exclude Laminar flow solution.
In Study-2: I solve the Heat and Laminar flow using the EC and MF calculated in STEP-1, using option "Values not solved for" I tried ALL and Automatic.
Yet, when I go to check Results .... I find that MF at time for example 0.5 seconds is Not The Same in the results of Study-1 and Study-2 ??!!! .. although I solved for MF ONLY in Study-1, so I expect to find the same results in Study-2 ..... I did that to double check that comsol reads the previous results correctly .. but there seem a problem or misunderstanding ?
1 Reply Last Post 2016/01/18 9:20 GMT-5
