2011/01/15 5:14 GMT-5
Hello again.
I see that after a weak and 88 views I still got no answer.
Is it even possible to simulate a particle beam with energy deposition into the thin plate?
All I need is a module which uses Bethe-Bloch formula.
Hello again.
2011/01/15 9:19 GMT-5
Did you look at the tutorials or documentations for the version you use? There are several materials such as modeling guide, releases, model library for AC module and so on. I suggest model library doc. especially since it has models implemented for several areas.
2011/01/25 14:38 GMT-5
Yes, I have gone through tutorials and manuals once more.But i still havent found a way to incorporate energy deposition of a beam of particles into the target. Any more practical advices on which module i should use or how to parse this problem? Is this even possible in Comsol?
Thanx
Thanx
2011/10/04 12:04 GMT-4
Thanx
Have you had any luck with this or responses elsewhere? What I've done up until now is plot the Lorentz Force using just the F=-q(v x B) portion since I am looking at only static magnetics, but I would be curious to see what you've learned.
~Brock
[QUOTE]
Thanx
[/QUOTE]
~Brock
