LiveLink for Matlab: access the edge of a Bezier curve
Hi everyone,
I'm trying to access a Bezier curve as an 'edge' in LiveLink for Matlab, but I cannot figure out how to do it. I want to create a sweep of a rectangle, following a Bezier curve 'b1'.
Here are some code and explanations:
% creation of Bezier curve 'b1'
model.geom('geom1').feature('wp3').geom.create('b1', 'BezierPolygon');
model.geom('geom1').feature('wp3').geom.feature('b1').set('p', {['-0.01295' '-0.01295';'0' '0.00466']});
model.geom('geom1').feature('wp3').geom.feature('b1').set('w', {'1' '1'});
model.geom('geom1').feature('wp3').geom.feature('b1').set('degree', {'1'});
% providing I have a face named 'r1', creation of a sweep of 'r1' following 'b1'
model.geom('geom1').create('swe1', 'Sweep');
model.geom('geom1').feature('swe1').label('Sweep 1');
model.geom('geom1').feature('swe1').set('crossfaces', true);
model.geom('geom1').feature('swe1').set('includefinal', false);
model.geom('geom1').feature('swe1').selection('face').set('wp2.r1', 1);
model.geom('geom1').feature('swe1').selection('edge').set( ??? );
model.geom('geom1').feature('swe1').selection('diredge').set( ??? );
Now, what should I write instead of the '???' to have my sweep follow the curve 'b1' ?
Thanks in advance for your replies :-)
1 Reply Last Post 2016/11/03 8:30 GMT-4
Posted: 8 years ago 2016/11/03 8:30 GMT-4
Hi Julien
The easiest way to figure out how to name things or call certain methods in the Comsol API is to set up the model in Comsol Multiphysics and export the model as an M-file using File->Save As.
I'm attaching a working example.
In order to learn about how geometry entities (objects) are named in Comsol you can consult the Comsol Programming Reference Manual and look in the section titled "Accessing Geometry Object Names" which includes a section on "Naming Of Geometry Objects".
If you need more information about the geometry such as boundary and edge numbers you should look for functions in the section titled: "Geometry Object Information".
Lars Gregersen
Comsol Denmark
Hi Julien The easiest way to figure out how to name things or call certain methods in the Comsol API is to set up the model in Comsol Multiphysics and export the model as an M-file using File->Save As. I'm attaching a working example. In order to learn about how geometry entities (objects) are named in Comsol you can consult the Comsol Programming Reference Manual and look in the section titled "Accessing Geometry Object Names" which includes a section on "Naming Of Geometry Objects". If you need more information about the geometry such as boundary and edge numbers you should look for functions in the section titled: "Geometry Object Information". -- Lars Gregersen Comsol Denmark
