2011/01/14 6:59 GMT-5
I'm not sure I'm getting exactly what you need, but generally you can use formulas in all (almost) fields of COMSOL, so why not rty it out on a simple verifiable example. Then it should be OK for a complex one ;)
2011/01/17 10:01 GMT-5
Dear Ivar,
the complexity is not my problem.
I just wonder how to refer to a spatial variable like x, y or z (cartesian) in a formula for a parameter.
Do you know, where to search for an answer?
Best regards
Arian
Dear Ivar,
Best regards
Arian
2011/01/17 10:37 GMT-5
there was a discussion, if I remember right, on one of the other treads (I'm seeing too many ;) with a reply from COMSOL I believe
2011/01/20 18:16 GMT-5
Thanks so far, I am still working on it... I found something but it did not really match my problems. I think, I will dive a bit deeper into this stuff. Unfortunately I find other people's results which must base on sth. like this but no explanation anywhere... but maybe I have simply not yet searched long enough. When I find a solution I will post it.
Best regards
Arian
Best regards
Arian
2011/04/07 9:00 GMT-4
Dear Arian,
I'm also interested about the RI variation profile as that of the the graded one. If you have got what you were looking for pls inform.
Partha
Dear Arian,
Partha
2011/07/08 15:48 GMT-4
I am also very interested. did you find a solution?
2011/11/15 3:55 GMT-5
You need to design several circles with gradient index. Or you can define the refractive index profile function for a core region.
SK Varshney
SK Varshney
2013/02/21 15:00 GMT-5
I'd figure it out and I'm posting it just for the record:
Expand the material node and create a function (right click) under the sub-node "Refractive index". After that, you can call the function inside this node by using the sintax:
functionName(param1, param2, ..., paramN)
hope this helps.
cheers,
Felipe BM
hope this helps.
cheers,
Felipe BM
