Optimization RF Module
I have a working model of an rf heating example and want to extend it as an optimization problem.
The model works well without optimization in which I want to maximize absorbed power that depends on only one dimension of the heated body geometry.
The absorbed power is evaluated as a derived result (ht.Qtot) in the original model. I tried to use it as an objection function in the Objective expression field but the solution goes on and on for hours and/or gives Out of Memory message, although the range of the chosen design parameter is very small and I using an i7 64-bit Laptop with 4 GHz RAM.
My questions are:
1. Can I use a derived solution directly as an objection function or need to redefine it as a global or local variable and how to define it?
2. which type of objective function is appropriate in this case Integral, probe ... etc.?
3. Is the given error message a genuine error or is due to the program going into empty endless loop?
0 Replies Last Post 2017/01/07 2:42 GMT-5
Hello Edriss Ali
