ultrasonic probe achieves self-sending and self-receiving
There is a ultrasonic probe that wants to transmit and receive signals simultaneously. That is, positive piezoelectric and converse piezoelectric are achieved simultaneously. So I want to use the Acoustic-Piezoelectric Interaction,Transient to achieve the goal. How can I set the boundary conditions to make the probe self-sending and self-receiving?
6 Replies Last Post 2017/05/25 9:31 GMT-4
Posted: 7 years ago 2017/05/21 5:39 GMT-4
Xuebin,
my first idea would be to connect some suitable kind of circuit physics to the piezoelectric electrodes.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Xuebin, my first idea would be to connect some suitable kind of circuit physics to the piezoelectric electrodes. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 7 years ago 2017/05/21 7:50 GMT-4
Thank you for your reply. Could you please describe it more detailed?Now, I only achieve the converse piezoelectric by the ultrasonic probe.How can I set the positive piezoelectric simultaneously?
Hi, Thank you for your reply. Could you please describe it more detailed?Now, I only achieve the converse piezoelectric by the ultrasonic probe.How can I set the positive piezoelectric simultaneously?
Posted: 7 years ago 2017/05/21 8:29 GMT-4
I suggest to check examples in the application library and other resources Comsol provides to you. Once you made a start you can address more specific questions.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
I suggest to check examples in the application library and other resources Comsol provides to you. Once you made a start you can address more specific questions. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 7 years ago 2017/05/21 9:07 GMT-4
Thank you,
I have got all the libraries, but I didn't find the positive piezoelectric process, and found no positive and negative piezoelectric simultaneously.Do you have some resources? I'd appreciate it.
Thank you, I have got all the libraries, but I didn't find the positive piezoelectric process, and found no positive and negative piezoelectric simultaneously.Do you have some resources? I'd appreciate it.
Dave Greve Certified Consultant
Posted: 7 years ago 2017/05/22 11:43 GMT-4
Your question is insufficiently clear to answer. It is possible you are thinking of one of two things:
1. Self-sensing piezoelectric transducers. Here the terminal impedance of the piezo is influenced by the attached structure. You would be interested in frequency domain analysis.
2. Pulse or radar-type interrogation. Here a short pulse excites an ultrasonic wave and the same transducer is used to detect the return pulse. A transmit-receive circuit is used to switch from transmit to receive mode. This mode is used both for flaw detection and medical imaging.
If you mean something else please try to explain it in more detail, maybe then you can be directed to useful examples.
DW Greve
DWGreve Consulting
Your question is insufficiently clear to answer. It is possible you are thinking of one of two things: 1. Self-sensing piezoelectric transducers. Here the terminal impedance of the piezo is influenced by the attached structure. You would be interested in frequency domain analysis. 2. Pulse or radar-type interrogation. Here a short pulse excites an ultrasonic wave and the same transducer is used to detect the return pulse. A transmit-receive circuit is used to switch from transmit to receive mode. This mode is used both for flaw detection and medical imaging. If you mean something else please try to explain it in more detail, maybe then you can be directed to useful examples. DW Greve DWGreve Consulting
Posted: 7 years ago 2017/05/25 9:31 GMT-4
Thank you very much. I have found a similar model. It is useful for me.
