2011/03/02 2:31 GMT-5
The default material library SiC (6H) is not set up for PZT convention material properties, only for standard structural.
In COMSOL the convention for PZT materials is different from standard structural materiela in the tensor order (IEEE convention) So you must adapt the tensor matrix. (But I didnt know that SiC was piezoelectric)
If it is because you use it as a structural material then you must add a "Linear Elastic Material Model" (right click the PZD main node) and define your domain to be for the SiC
2011/03/02 7:44 GMT-5
Thank you for the help. I'm going to need to look into this more thoroughly before simulating anything. I'm new to using COMSOL so I'm learning while I try to figure this all out. In 3.5 it would allow me to simulate using 6H-SiC and the Piezosolid model, but that may have been drastically inaccurate if the default parameters are not configured for the Piezosolid model. I'm looking into the piezoelectric effect of SiC, actually 3C and not 6H, for the use in a pressure sensor, however it may be the piezoresistive properties that I will be utilizing and not actually the piezoelectric properties. Thanks again for the help.
