2011/03/12 5:18 GMT-5
it's related to the early version 4.0, when I load it into my 4.1 I delete the solution and run it, it starts to solve but then crashes comsol fully ;) translations not 100% OK
But you are asking the system to be slightly schisophrenic there by having the initial conditions of the domain at -20°C and then its border at 0°C
2011/03/12 10:46 GMT-5
What is "schisophrenic" ?
I think the initial temperature values are no problem, because the model can work when involved only Heat transfer physics. The reason that makes me think of "too large mesh deformation" is that when I use the ALE method, I often encounter this Error "Failed to find consistent initial values", especially when the moving boundary is a little bit complex, and sometimes I can fix it by some tricks, like refine the mesh.
[QUOTE]
[/QUOTE]
2011/03/13 6:25 GMT-4
It was just my comment about an initial boundary value of "0" while the domain has a Temperature of "-20" One could assume that the boundary is either at the temperature of the body=domain, or somewhere intermediate, anyhow there should come a gradient. But I agree, as initial conditions it should hold and be OK.
The other point is that I had no ALE in the model I looked at ? is ALE or a "level set" method the most appropriate for phase changes ? I'm not sure this no my usual physics domain so I'm also learning ;)
