Extract mass matrix using matlab
how to extract mass matrix from comsol/matlab, for a 3D > Solid Mechanics > Eigenfrequency Analysis model? Can't find it in documentation.
5 Replies Last Post 2011/05/07 6:48 GMT-4
Posted: 1 decade ago 2011/03/15 11:32 GMT-4
Search for "state space" or "mphstate()"
By the way the doc is slightly misleading, here is a code that works for the doc (I received it from Remi of COMSOL support)
% Load the heat_convection_2d.mph model
model = mphload('heat_convection_2d.mph');
% Set the temperature condition with a constant parameter
model.param.set('T0','373');
model.physics('ht').feature('temp1').set('T0', 1, 'T0');
% Add a point probe at [0.3;0.8]
pdom1 = model.probe.create('pdom1', 'DomainPoint');
pdom1.model('mod1'); pdom1.setIndex('coords2','0.8',0,0);
pdom1.setIndex('coords2','0.3',0,0);
% Extract matrix data
M = mphstate(model,'sol1','out',{'MA' 'MB' 'C' 'D'},...
'input','T0', 'output', 'mod1.ppb1');
At least this works OK for 4.1 ;)
Hi Search for "state space" or "mphstate()" By the way the doc is slightly misleading, here is a code that works for the doc (I received it from Remi of COMSOL support) %%%%%%%%%%%%%% % Load the heat_convection_2d.mph model model = mphload('heat_convection_2d.mph'); % Set the temperature condition with a constant parameter model.param.set('T0','373'); model.physics('ht').feature('temp1').set('T0', 1, 'T0'); % Add a point probe at [0.3;0.8] pdom1 = model.probe.create('pdom1', 'DomainPoint'); pdom1.model('mod1'); pdom1.setIndex('coords2','0.8',0,0); pdom1.setIndex('coords2','0.3',0,0); % Extract matrix data M = mphstate(model,'sol1','out',{'MA' 'MB' 'C' 'D'},... 'input','T0', 'output', 'mod1.ppb1'); %%%%%%%%%%%%%% At least this works OK for 4.1 ;) -- Good luck Ivar
Posted: 1 decade ago 2011/04/01 12:19 GMT-4
Hi Ivar,
Did you verify that the solution you get from using the state space matrices is the same as the solution you get from the COMSOL GUI?
V/R,
Andrew Wang
Hi Ivar, Did you verify that the solution you get from using the state space matrices is the same as the solution you get from the COMSOL GUI? V/R, Andrew Wang
Posted: 1 decade ago 2011/05/03 11:02 GMT-4
Hi Andrew
I have not worked on it since last week -- I will hopefully get it done within a couple of days and then will let you know.
However, for the simple 2D heat-transfer problem (non-coupled, single physics problem), I believe it should give more or less the same results. But I will update once I have implemented it.
Madu
Hi Andrew I have not worked on it since last week -- I will hopefully get it done within a couple of days and then will let you know. However, for the simple 2D heat-transfer problem (non-coupled, single physics problem), I believe it should give more or less the same results. But I will update once I have implemented it. Madu
Posted: 1 decade ago 2011/05/06 16:40 GMT-4
I worked this example in MATLAB (LiveLink), literally cutting and pasting from Ivar's example. MATLAB throws no errors, but the 'C' matrix is empty which is something I would not expect considering the probe. Also, I slightly modified the example by asking for the 'A' and 'B' matrices vice the 'MA' and 'MC' matrices. In these cases, I get the following error:
??? Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: Unknown property
Unknown property
- Property: A
Does someone on this Forum know if there are some bugs in the code? If so, has anyone heard when a fix is due out?
Thanks to all who take the time to answer this forum! You are doing a great service to us 'new-to-COMSOL' folks.
I worked this example in MATLAB (LiveLink), literally cutting and pasting from Ivar's example. MATLAB throws no errors, but the 'C' matrix is empty which is something I would not expect considering the probe. Also, I slightly modified the example by asking for the 'A' and 'B' matrices vice the 'MA' and 'MC' matrices. In these cases, I get the following error: ??? Java exception occurred: Exception: com.comsol.util.exceptions.FlException: Unknown property Messages: Unknown property - Property: A Does someone on this Forum know if there are some bugs in the code? If so, has anyone heard when a fix is due out? Thanks to all who take the time to answer this forum! You are doing a great service to us 'new-to-COMSOL' folks.
Posted: 1 decade ago 2011/05/07 6:48 GMT-4
I have not fully amnaged to get it eitherworkin under v4.1, so I'm waiting for 4.2. But there was another thread the last days, I believe using JAVA describing how to (or what is Matlab ?, I'm looking at to many threads here ;)
oups it was the next thread in the list, here is the link
www.comsol.eu/community/forums/general/thread/13667/#p49298
Hi I have not fully amnaged to get it eitherworkin under v4.1, so I'm waiting for 4.2. But there was another thread the last days, I believe using JAVA describing how to (or what is Matlab ?, I'm looking at to many threads here ;) oups it was the next thread in the list, here is the link http://www.comsol.eu/community/forums/general/thread/13667/#p49298 -- Good luck Ivar
