Mass flow rate in heat transfer model
I'm currently busy with a model for scalp cooling. This means the head is cooled with a cold fluid that flows through a cap wich is placed over the head. I know this cooling fluid gets warmer as a result of the biological heat transfer. But this heat will be taken away because of the mass flow system of the cooling cap.
My problem is that I don't know how to model this mass flow. If someone could explain me how to make a mass flow inlet with a certain temperature and volume and a mass flow outlet with the same volume but warmer because of the biological tissue heat transfer I would be very gratefull.
Sincerly,
Max Graduate student applied physics
1 Reply Last Post 2017/09/25 2:55 GMT-4
Posted: 7 years ago 2017/09/25 2:55 GMT-4
Dear Max ,
I suggest you send your question directly to support@comsol.com.
Kind regards,
Yara Soares
COMSOL BV | Röntgenlaan 37 | 2719 DX Zoetermeer Phone: +31 (0)79 363 4230 | Fax: +31 (0)79 361 4212
www.comsol.nl | yara.soares@comsol.com
Dear Max , I suggest you send your question directly to support@comsol.com. Kind regards, Yara Soares ---------------------------------------------------------------------- COMSOL BV | Röntgenlaan 37 | 2719 DX Zoetermeer Phone: +31 (0)79 363 4230 | Fax: +31 (0)79 361 4212 www.comsol.nl | yara.soares@comsol.com ----------------------------------------------------------------------
