Body fixed coordinate system
I have a question on how to create a body fixed coordinate system. I am performing a simulation with a rotating magnet. At this point a implemented the magnets magnetisation using the global coordinate system... But I need an axial magnetisation, therefore the magnetisation axis should rotate according to the magnet rotation.
Thank you in advance Michael
2 Replies Last Post 2017/10/02 10:01 GMT-4
Nirmal Paudel Tribhuvan University/Electrical Engineering
Posted: 7 years ago 2017/10/02 9:32 GMT-4
Hi Michael,
If you use the "Rotating Machinery, Magnetic (rmm)" physics interface in AC/DC Module, it will be very easy and automatic to apply the radial or axial magnetization as done in the following examples. I would suggest you to take a look and apply the same method in your modeling needs. 1. https://www.comsol.com/model/generator-in-2d-2122 2. https://www.comsol.com/model/electrodynamic-wheel-magnetic-levitation-in-2d-44871
Best Regards, Nirmal Paudel
Hi Michael, If you use the "Rotating Machinery, Magnetic (rmm)" physics interface in AC/DC Module, it will be very easy and automatic to apply the radial or axial magnetization as done in the following examples. I would suggest you to take a look and apply the same method in your modeling needs. 1. https://www.comsol.com/model/generator-in-2d-2122 2. https://www.comsol.com/model/electrodynamic-wheel-magnetic-levitation-in-2d-44871 Best Regards, Nirmal Paudel
Posted: 7 years ago 2017/10/02 10:01 GMT-4
Hi Nirmal
Thanks for your fast response. Sorry, I may have explained my situation a little bit too simplified... I have a flexible catheter with a magnet on it's tip. I'm trying to simulate the behaviour/deformations of this catheter when a magnetic field is applyed. Based on my knowlege the tip of the catheter should be displaced and rotated in order to align with the magnetic field... So far I used a combination on magnetic fields, no currents and solid mechanics... But, as said, i'm not able to model an axial magnetisation. As it is not a simple ratation I can't use a cylindrical coordinate system with fixed origin. I was not able to find how to fix a coordinate axis to a body axis.
Best Michael
Hi Nirmal Thanks for your fast response. Sorry, I may have explained my situation a little bit too simplified... I have a flexible catheter with a magnet on it's tip. I'm trying to simulate the behaviour/deformations of this catheter when a magnetic field is applyed. Based on my knowlege the tip of the catheter should be displaced and rotated in order to align with the magnetic field... So far I used a combination on magnetic fields, no currents and solid mechanics... But, as said, i'm not able to model an axial magnetisation. As it is not a simple ratation I can't use a cylindrical coordinate system with fixed origin. I was not able to find how to fix a coordinate axis to a body axis. Best Michael
