2011/04/11 6:08 GMT-4
Just solved it - should have read the LiveLink-manual more carefully :) It is neccessary to import the Comsol classes first:
function myFunction()
import com.comsol.model.*
import com.comsol.model.util.*
model = ModelUtil.create('Model');
return
return
2011/05/10 17:36 GMT-4
Hey i ask the same
thanks for your answer tomorrow i'll try it too
i want to make my model in comsol as a function in matlab and then i do sort of parametric
sweep on this model by using a for loop calling my model function and always with sweeping parameter
thanks a lot
and you think your advices here will work for me too?
Arye
Hey i ask the same
thanks a lot
Arye
2011/05/11 13:35 GMT-4
Thanks it worked you are awesome
2011/11/02 4:39 GMT-4
We need install LiveLink before using matlab combined with comsol v4?
2011/11/02 5:30 GMT-4
Indeed you need a corresponding Matlab installed, then COMSOL With the Matlab livelink for V4 to get everything running together. Cehck with your local rep, or on the KB for install details
2012/02/01 11:33 GMT-5
As an addition to the explanation from "Chris Shor"; it is also possible to run a LiveLink operation to start model implamentation without creating a MATLAB function file. That was especially helpful (and seems faster) in my case, since I have pre-processing of my data before starting model implementation.
To do so;
..._______________________________________________
%% PRE_PROCESSING
% constants
x = 1;
y = 2;
z = 3;
%% MODEL IMPLEMENTATION
mphstart % connect MATLAB to the COMSOL server (in default port)
import com.comsol.model.* % import the COMSOL classes
model = ModelUtil.create('Model'); % start model implementation
model.name('xxx');
model.param.set('x', [num2str(x) 'unit'], 'explanation'); % define global model parameters (constants)
model.param.set('y', [num2str(y) 'unit'], 'explanation');
model.param.set('z', [num2str(z) 'unit'], 'explanation');
return
Hopefully that will be helpful.
(LiveLink for MATLAB Users Guide - p.12-14)
COMSOL 4.2a
Ubuntu 11.04
MATLAB R2010a
To do so;
%% PRE_PROCESSING
% constants
x = 1;
y = 2;
z = 3;
model.name('xxx');
return
COMSOL 4.2a
Ubuntu 11.04
MATLAB R2010a
