Mr.Ivar, could you check it for me again?
Posted 2011/04/11 15:32 GMT-4 Fluid & Heat, Mesh, Studies & Solvers, Structural Mechanics Version 3.5a, Version 4.1 2 Replies
Hi Mr ivar,
According to your suggestions, I try to fix it and I still have something really confused!
This is the precious suggestions that you give to me!
there are many things here that I do not really catch, but I believe also it's because I do not fully understand your model, a few items I can suggest to check:
1) you could probably use the FSI module, as there all three physics are already combined
2) the inlet 1 you set up the velocity with an "s" but you have 3 segments, and s is redefined on each going from 0, to 1 along the edge, have you checked that the initial value velocity is already more or less as expected ?
3) I do not understand "inlet 2" this is a wall not an inlet ? I'm missing something ;)
4) boundary loads 1 and 3 of "0" do not bring anything
5) in the solid Mechanics do not leave an entry empty, add a "0" to the xref (even if you do not use it)
6) in the moving mesh, by default everything is fixed, I believe you should set a free deformation to the fluid part
7) your prescribed mesh displacement is not set you need to define something also for the boundaries
8) remove the not used solver cases and keep only one
9) try to solve only one physics at the time, to check that they are ok, you can also just get the initial conditions loaded to test those also
Here is my confusions:
About 2) the three segments in inlet 1 ,3,5 has the same conditions. Does I make some mistakes here?
3) inlet 2 , actually it is the inner boundary of the fluids, it has the same velocity as the inner boundary of the membrane.
4)boundary loads 1 and 3 , I want to do is they are like fixed, should I use the prescribed displacement? I check in the old version 3.5, it should use “standard notation" , Rx 0m Ry 0 m
7) prescribed mesh displacement is the membrane's mesh displacement, so I think it should be u2 and v2, is it right?
My model is about the single valve, the domain 4 8 9 13 15 is the solid membrane, when the flow enters from left to right, I need to find out how the membrane acts and how the fluids act.
Thank you so much!
Thank you so much!
2 Replies Last Post 2011/04/12 12:02 GMT-4
