Call a function in "mesh size" node
It is a very simple test model:
A fluid flows in a rectangular 2-d channel (from the left to the rigth).
Global ->Parameters : H = 0.1 (it is the heigth of the channel)
Mesh ->Size -> Maximum element size : H
It works. But if I define a function
model ->analytic : myfun(x) = x/10
Mesh ->Size -> Maximum element size : myfun(H)
It doesnt works. I think that it means that a Mesh cannot be defined by a function. I tried to enter
Mesh ->Size -> Maximum element size : max(H)
and it didnt work. Can you confirm that a mesh cannot be defined with functions ? Is there a way to define a mesh with a complicated function of a global parameter ? (e.g, piecewise function of H)
Thank you.
5 Replies Last Post 2011/04/23 16:19 GMT-4
Posted: 1 decade ago 2011/04/21 19:02 GMT-4
Indeed you cannot call a function, but you can write H/10 directly in the formula field
Hi Indeed you cannot call a function, but you can write H/10 directly in the formula field -- Good luck Ivar
Posted: 1 decade ago 2011/04/22 14:42 GMT-4
I would like to set my "Mesh->MaximumElementSize" as a piecewise function. In fact, I found that:
1. when H is large, (MaximumElementSize = H/10) provides a good initial mesh (for adaptive mesh)
2. when H is very small, (MaximumElementSize = 1) provides a good initial mesh (for adaptive mesh)
In this case I need a piecewise function of H to set a good initial mesh regarless for all value of H.
How would you do that ?
[QUOTE] Hi Indeed you cannot call a function, but you can write H/10 directly in the formula field -- Good luck Ivar [/QUOTE] I would like to set my "Mesh->MaximumElementSize" as a piecewise function. In fact, I found that: 1. when H is large, (MaximumElementSize = H/10) provides a good initial mesh (for adaptive mesh) 2. when H is very small, (MaximumElementSize = 1) provides a good initial mesh (for adaptive mesh) In this case I need a piecewise function of H to set a good initial mesh regarless for all value of H. How would you do that ?
Posted: 1 decade ago 2011/04/22 17:17 GMT-4
have you tried a chain of boolean expresions ?
Something like
h = 1/(1+ 2*(H<3) + 4*(H<6) ...)
It might work, haven't checked ;)
Hi have you tried a chain of boolean expresions ? Something like h = 1/(1+ 2*(H
Posted: 1 decade ago 2011/04/23 13:04 GMT-4
Something like
I tried boolean expresion and unfortunately it is not accepted in the mesh size settings..
Any other ideas ?
[QUOTE] Hi have you tried a chain of boolean expresions ? Something like h = 1/(1+ 2*(H
Posted: 1 decade ago 2011/04/23 16:19 GMT-4
then for me it means that the mesh fields it accepts only "Parameters" (=Constants).
Pameters are be defined once at solver launch, and may be changed via a reference in a "Parametric sweep", or a "Solver Continuation sweep"
Hi then for me it means that the mesh fields it accepts only "Parameters" (=Constants). Pameters are be defined once at solver launch, and may be changed via a reference in a "Parametric sweep", or a "Solver Continuation sweep" -- Good luck Ivar
