Global Definitions > Parameters vs numerical values.
Posted 2011/05/16 2:59 GMT-4 Low-Frequency Electromagnetics Version 4.1 1 Reply
Hello dear users,
My following problem is the following one:
In Global Definitions > Parameters, I put the following values:
Name Expression Value
Rp 8[m] 8m
r1t Rp 8m
z1t 5*Rp 40m
r2t z1t*cos(pi/3) 20m
z2t z1t*sin(pi/3) 34.64m
In Model1 > Geometry > Circle 4, I put:
In Position:
Base: Center
r: r2t+Rp
z: z2t
The problem is that the value I give to the variable "z" doesn't take it correctly, it is taken as zero, neither the value of "r=r2t+Rp" and finally, the circle isn't lay in the correct position.
However, if I put the values of "r" and "z" with its number value (28 and 34.64, respectively), the circle is located correctly.
I mean, in Model1 > Geometry > Circle 4, I put:
In Position:
Base: Center
r: 28
z: 34.64
where the mistake can be ? What am I doing in the bad way?
Thanks in advance.
Isa
Rp 8[m] 8m
r1t Rp 8m
z1t 5*Rp 40m
In Position:
Base: Center
r: r2t+Rp
z: z2t
In Position:
Base: Center
r: 28
z: 34.64
Thanks in advance.
Isa
1 Reply Last Post 2011/05/17 4:54 GMT-4
