finding special coordinates
hi,
I want to know if it is possible to find the coordinates that for example the velocity is maximum ?
i have solved a fluids model and I want to know the exact location of the maximum velocity ?
is it possible ?
1 Reply Last Post 2011/06/03 16:03 GMT-4
Posted: 1 decade ago 2011/06/03 16:03 GMT-4
search the forum, it has been discussed a few times, the min() and max() accept two operands, the secons defines which of the coordinates to reply where, the first one is min, respectively max. It's also documented in the help files, but, it's not mentionned aîn all min and mayx references, you need to search a little there too
Hi search the forum, it has been discussed a few times, the min() and max() accept two operands, the secons defines which of the coordinates to reply where, the first one is min, respectively max. It's also documented in the help files, but, it's not mentionned aîn all min and mayx references, you need to search a little there too -- Good luck Ivar
