Mesh Problem with helix
Posted 2011/08/09 9:06 GMT-4 Fluid & Heat, Geometry, Mesh Version 4.1 3 Replies
I´m actually trying to simulate the flow in a 3D Helical-like solid. The problem is that I alwas get an error during meshing the surface.
Is it possible that this is an dimension issue? becaus the small radius is int the order of µm and the bigger radius in the order of cm?
Thank you very much for your help.
Kind Regards ,
Albert
Kind Regards ,
Albert
3 Replies Last Post 2011/08/19 9:52 GMT-4
