temprature dependant material properties
i am using copper electrodes and steel sheets in welding model i want to model the material properties such as resistance thermal conductivity as temperature dependent .
kindly tell me how to define these material properties as temperature dependent in the simulation
1 Reply Last Post 2011/09/19 5:56 GMT-4
Posted: 1 decade ago 2011/09/19 5:56 GMT-4
many of the material properties are already temperature dependent, take a look. Basically you defne a function (interpolation or tabular) and refer the material properties to this function. check the doc there is more on that in the material section
Hi many of the material properties are already temperature dependent, take a look. Basically you defne a function (interpolation or tabular) and refer the material properties to this function. check the doc there is more on that in the material section -- Good luck Ivar
