Using results from one simulation run as initial conditions for next simulation run
Posted 2011/10/24 14:45 GMT-4 Fluid & Heat, Results & Visualization, Studies & Solvers Version 4.2 3 Replies
I am trying to create a model (one component diffusing into the surrounding component) which involves diffusion at 2 temperatures (4C and 30C). The diffusing agent diffuses a certain distance at 4C and then the temperature changes to 30C. The diffusivity values at these 2 temperatures are also different.
I want to use the results from the diffusion at 4C as the initial conditions for the diffusion at 30C. Is there any way I can do the same?
Any help/advice would be greatly appreciated.
Thanks in advance!!
Radhika
Thanks in advance!!
Radhika
3 Replies Last Post 2011/10/27 9:52 GMT-4
