Hello Ke Wang
2011/11/21 11:46 GMT-5
Have u slove the problem? I have the same question.
9 years ago
2015/11/04 7:58 GMT-5
Reviving this thread!
Does anyone know the answer?
If I plot the cut line through the center is there a a simple way of extracting the 1/e width and exporting into a table from that graph?
9 years ago
2015/11/04 8:42 GMT-5
Acording to
www.rp-photonics.com/effective_mode_area.html
A_eff= int I dxdy / int I^2 dxdy
Which means that using two Derived values" i.e. the integrals of emw.Poavz and emw.Poavz^2 and deciding one by the other the answer is achieved.
However the two values end up in two different tables and I can not plot one table divided by the other. So Ig guess I have to store the sol in tables on file import to matlab perform the division and then export to a similar table on file that then can be plotted...
Acording to https://www.rp-photonics.com/effective_mode_area.html
Jeff Hiller
COMSOL Employee
9 years ago
2015/11/04 8:57 GMT-5
Hello Micke,
You could use Component Couplings of the Integration type to compute the integrals. This way each integral has a name and you can divide one by the other within COMSOL. Use "Update Solution" to evalaute the component couplings without having to recompute the solution.
Hello Micke,
