Electrowetting modeling questions
Good morning. I followed the "Electrowetting Lens" example from the Application Gallery. The original model works well. Then I try to change the shape and material of the two fluids. I want to simulate the contact angle changing of a droplet on a dielectric film when appling voltage. But some errors happened when computing. It shows "Repeated error test failures. May have reached a singularity. Last time step is not converged." I attached my mph file. How could I solve this problem to run this model sucessfully? Thank you in advance.
1 Reply Last Post 2019/11/08 14:15 GMT-5
Posted: 4 years ago 2019/11/08 14:15 GMT-5
Hi Ginger, If you solved this problem and simulated it, then please reply by attaching the .mph file,that will be helpfull for me. Thank you
