Hello Saeid Movahed
2012/02/28 3:43 GMT-5
Hi Saeid
i am having the similar problem. did you find answer for that.
Omer
Hi Saeid
Omer
2012/03/04 9:50 GMT-5
Hi Omer
Sorry, I could not find the solution for the problem. Actually, I do not know what to do!!
Hi Omer
2012/03/06 3:13 GMT-5
I'm having the same type of "new geometry"-related problem as you have. I have asked for help in the thread linked to below but so far no ideas on what is the problem.
www.comsol.se/community/forums/general/thread/26593/
I've tried clearing the old solutions but that did not change anything. When I did export the new geometry to a new COMSOL file it worked but it would of course be better to have everything in one file.
http://www.comsol.se/community/forums/general/thread/26593/
2012/03/10 17:05 GMT-5
It is strange, in my model, all the modeling proceses are the same as comsol library model(Batteries and fuel cells>>ht_PEM), and just geometry has been more complex,
I am confused and Ido not know what the problem is!
2012/12/04 19:36 GMT-5
Guys I am in the same boat with you all. I just changed the geometry to a long channel with entrance at one of the end's and renamed the file, rest everything was left unchanged from COMSOL's example, I get the same error. Did anyone figure this out ? Could it be the number of iterations that have to changed. I doubt that is the problem as the solver quits almost instantaneously when asked to solve.
I was however able to use a little bit different geometry but I think it was about the same size of the example. It solved completely fine.
Any suggestions ?
Any suggestions ?
