2012/01/10 6:48 GMT-5
Hi Steven,
principally you can do everything with the basic module if you are willing to implement the equations of your model by yourself.
If you want to make your life easier and you are willing to spend the money then the heat transfer and the RF module might cover your physics.
Cheers
Edgar
Hi Steven,
Cheers
Edgar
2012/01/10 7:03 GMT-5
Thanks for the reply Edgar.
Something which I forgot to add and is rather crucial, is that the temperature jump which I wish to simulate is from 1.5K to 300K. In this temperature temperature range, a number of physical properties such as the specific heat capacity and thermal conductivity will change drastically so is COMSOL able to simulate these changes too?
2012/01/10 7:11 GMT-5
Yes, all material properties can be defined as functions of temperature and any other variable. Of course it may not be trivial to really solve highly nonlinear models.
Cheers
Edgar
Cheers
Edgar
2012/01/11 4:36 GMT-5
Thanks Edgar, I'll give it a go.
Steven
Steven
2012/01/19 7:35 GMT-5
I've created an Interpolation table for my figures but not sure how to incorporate it into my model. The figures are for the specific heat capacity so I've created a user-defined property in my materials but not sure what to do next. My table (function name) is called SHC.
Furthermore, the headings in the table are t and f(t) suggesting a time and a function of time rather than temperature which is what I want, should I be concerned with this?
2012/01/19 8:18 GMT-5
Hello
Why not load in a material with a T dependence and see how its done, that should give you the tips needed
Hello
2012/01/26 6:46 GMT-5
Thank you for all the input so far, I appreciate it hugely.
I've managed to find a material that has a property variance in temperature but I can't seem to apply it to my model. The physics I am using is the coefficient form of a PDE but even though it appears I can assign the model with a material, when I assign the model with another material, I get the same result from the simulation.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
2012/01/26 10:06 GMT-5
have you checked the help about:
Variable Naming Convention and Scope
New Functionality in Version 4.2a
"New material container variable root.material simplifies access to material data. For example, "root.material.rho" is the density ρ as defined by the materials in each domain in the geometry. For plotting, you can type the expression material.rho to create a plot that shows the density of all materials."
