Phase angle in RF frequency domain study
Dear All,
I am currently doing some work on antennas. I am performing frequency domain studies to look at the impedance match and the far field pattern of the antenna.
The antenna is intended to produce circular polarization, i.e. the E-vector rotates by 360° around the propagation direction during a period of the exciting signal.
Now the question: Is it possible in a frequency domain study to look at the far field results at different phase angles? This would reveal to what degree the antenna pattern is circular or elliptic.
I already tried to set different angles in the Results > Data Sets > Solution field. But this didn't change the result plots in any way.
Will I need to do a transient study for that? Any ideas?
Thank you,
Edgar
2 Replies Last Post 2012/01/20 3:33 GMT-5
Posted: 1 decade ago 2012/01/17 11:19 GMT-5
Hi Edgar
Interesting question you have there, can you do something with a polar plot ?
My 4.2a model is really lazy and its' 2D, in 3D one would need to define the nx,ny,nz and make something like a cut plane there through someway.
not sure I got it right anyhow ;) Just a 5 min test out
Hi Edgar Interesting question you have there, can you do something with a polar plot ? My 4.2a model is really lazy and its' 2D, in 3D one would need to define the nx,ny,nz and make something like a cut plane there through someway. not sure I got it right anyhow ;) Just a 5 min test out -- Good luck Ivar
Posted: 1 decade ago 2012/01/20 3:33 GMT-5
Hi Ivar,
thanks for the reply. The issue was resolved by the COMSOL support in the meanwhile. It was actually correct to set the phase angle in the solution, but only the scalar field components are phase dependent, the norm-values are calculated from a full period.
And indeed, I think the polar plots are very well suited to display the results.
Cheers
Edgar
Hi Ivar, thanks for the reply. The issue was resolved by the COMSOL support in the meanwhile. It was actually correct to set the phase angle in the solution, but only the scalar field components are phase dependent, the norm-values are calculated from a full period. And indeed, I think the polar plots are very well suited to display the results. Cheers Edgar
