Non-Isothermal Flow, initial values and bias: am I doing something wrong?
Posted 2012/02/02 3:56 GMT-5 Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Studies & Solvers Version 4.2 1 Reply
Good morning!
I'm simulating a water-cooling device for a heated cylinder and I'm testing different geometries.
The standard geometry would be a heated cylinder cooled on the sides by a water film (-> I'm using the physics "Non-Isothermal Flow").
I'm now trying to test cylinders of different thicknesses; however, the computation will not converge if I don't impose proper Initial Values.
I've then tried to start from a simple (thick enough) geometry (that converges quite easily) and slowly decrease the thickness of my cylinder. I have created two different studies and I feed one study with the Solution of the other (in order to have the Initial Values reasonably close to the final solution), once I've slightly changed my geometry.
It seems to be working (almost) well. But my question now is: am I doing the right thing? Will COMSOL give me the right solution or by doing this "loop" (Study 1 - Study 2 - Study 1) I'm introducing some "bias" (i.e. I'm forcing a solution in one direction)?
Thanks a lot for your help!!!
Best wishes,
/Andrea
Best wishes,
/Andrea
1 Reply Last Post 2012/02/02 4:06 GMT-5
