Problem with Fluid Structure Interaction Model
Posted 2010/01/13 16:59 GMT-5 Fluid & Heat, Microfluidics 2 Replies
I'm using the Fluid Structure Interaction (FSI) Model from Model Library>MEMS module>Microfluidics Models (the one with a vertical obstacle inside a flow channel). I'm trying to solve the same model with different material properties, but i'm getting an error.
From options>constants menu i'm keeping all the default property values except for "eta" (fluid viscosity). I'm changing it to 315 instead of 0.001. Keeping all other properties and parameters same, while solving it, i'm getting the following error:
Error: Time 0: Nonlinear solver interrupted since convergence rate above limit. Last time step is not converged.
I've checked the nonlinear settings under solver parameters>time stepping and unchecked the box for "use limit on convergence rate", but still the solution didn't work. This time i've got the following error:
Error: Time 0: Nonlinear solver did not converge
The modified "eta" value is much higher from the original and it is just because the fluid i want to use is very viscous.
Any idea how to avoid this problem? Any insight would be much appreciated.
Thanks for your time.
2 Replies Last Post 2010/01/14 0:17 GMT-5
