2D plot from a parametric sweep in 1D geometry
Hello I've performed a parametric sweep in 1D geometry and would like to plot some of the results as function of both the x coordinate and the parameter I'm changing. When I add a 2D plot group I can't choose any dataset to plot with. When I add 1D groups I can, so I suspect it's because the model geometry is lower than 2D... Any ideas how I could do this?
Thanks Eyal
2 Replies Last Post 2020/07/30 11:38 GMT-4
Posted: 4 years ago 2020/07/30 6:30 GMT-4
You can use a Parametric Extrusion 1D dataset: It extrudes the 1D geometry into a 2D geometry where the x-coordinate is the x-coordinate in the 1D geometry and the y-coordinate is the parameter that you've swept over.
Posted: 4 years ago 2020/07/30 11:38 GMT-4
Thank you, that's just what I needed.
