"Heat Transfer in Fluid" between "2 Solid Mechanics"= ALE?
Posted 2012/04/23 12:28 GMT-4 Heat Transfer & Phase Change, Geometry, Mesh, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers, Structural Mechanics Version 4.2a 3 Replies
I have been all the day long reading about it and I could not figure out how to solve it. Many people have problems releated.
Thats the scheme of the problem:
Solid Mechanics (model3)
Heat Transfer in Fluids (model 2)
Solid Mechanics (model 1)
Each one is in a different model. So I have 2 displacement fields from model 1 and 3.
I need to modify the MESH of the model 2 to adjust the thickness of the fluid film. I have been using the ALE physics because it seems perfect for my case. However I did not succeed.
Reading a lot I implement the MODEL 2 this way:
1st: Movin Mesh(ALE)
2nd: HT in Fluids
(Quadrangular Finer Mesh+Swept)
How to input both displacement fields? (In 3.5 u had the "physics induced diplacement" option (Chapter 16 Modeling Guide 3.5), how can you do it with the 4.2a?
Thanks in Advance
2nd: HT in Fluids
Thanks in Advance
3 Replies Last Post 2012/04/27 11:08 GMT-4
