Problem with revolve object and matlab
Posted 2012/05/11 5:22 GMT-4 Interfacing Version 4.2 0 Replies
I'm trying to make a basic horn by revolving a 2D exponential curve around an axis. If i make it in Comsol, the revolving operation works fine. But if I use Matlab, it doesn't want to set the right revolving axis, no matter what I do.
I used "Save as model M-file" to generate the matlab file. So, it should do exactly the same as in Comsol. I don't understand why it gives this result. I attached the Comsol file and the Matlab file generated from it.
Do I need to set an additional parameter in Matlab ? Is there a trick to make it work ?
Ugo
Hello Ugo Marchand
