Hello Josh Thomas
2012/10/05 2:14 JST
Dear Josh,
unfortunately I have not read your post earlier: hope it's not too late!
The models that you have tested are provided to test proper operations of the cluster, not performance. For performance, you'd better try to reproduce the results of the following paper, based upon models also available in the model library, for the same number of DOFs:
www.comsol.fr/papers/10248/
Stephan
www.comsol.fr
Dear Josh,
The models that you have tested are provided to test proper operations of the cluster, not performance. For performance, you'd better try to reproduce the results of the following paper, based upon models also available in the model library, for the same number of DOFs: http://www.comsol.fr/papers/10248/
Stephan
www.comsol.fr
Josh Thomas
Certified Consultant
2013/01/30 6:59 JST
Stephan,
Thanks for the reply. I did have a chance to review Freels work and get comparable speed-up results for some of my own large memory models (upwards of 2.5 MDoF). Part of the issue was getting our HPC system interfacing properly with the COMSOL batch commands and PBS scheduler for optimal advantage of the cluster. The other part related to what you brought up about using a good test model. I've seen that until my models go beyond 1 or 2 MDoF that the speedup is minimal across clusters. But, in those cases, my workstation works great for these anyways!
Thanks again for the reply,
Josh
Stephan,
Josh
