2012/05/31 16:29 GMT-4
replace your usage of the mua[Pa*s] by mua(T). You need to tell COMSOL to use the temperature explicitely, in the analytical function definition the argument nameis a local "dummy" name, not linked to the true variable names.
Then as you have already defined the units in the analytical functions, you do not need to add tem again, else you will "suare" the units
2012/06/01 5:22 GMT-4
Hello Ivar,
I´ve subsituted mua Pa*s with mua (T) but it still doesnt work. Am I missing something?
Thx for your response!
Hello Ivar,
2012/06/01 6:07 GMT-4
if you look up a few materials there are several with T or p dependance, compare the COSMOl way and yours
2012/06/01 15:15 GMT-4
you need finally to write
mua(T[1/K])
obviosly in v4.2a everything is not yet up for the units in operators. with this it runs without warnings, but I cannot tell if your results are correct, as I'm not really understanding what you are doing ;)
Ony suggestion: consider smoothened step or rect function for your transitions, as "dirac type too steep transisitons tend to give solver issues
mua(T[1/K])
