How to call an interpolation function from a method?
I have a couple of interpolation functions in the definitions node for component 1. I am using model methods to do some of the more complicated model set-up for an analysis I am working on. It would be really helpful to be able to call an interpolation function from a method, but I can't figure out to do this call. I see how to set parameters in the interpolation node, but not how to compute a result. Conceptually, I'd like to be able to do something like:
double interpvalue = model.component("comp1").func("int5").computeValue(12, 13);
Any hints would be much appreciated!
2 Replies Last Post 2021/09/27 8:36 GMT-4
Posted: 3 years ago 2021/09/27 3:48 GMT-4
For an interpolation function defined in the Global Definitions I think that
model.param().evaluate("int5(12,13)")
should work, but I don't think that there's anything similar available for functions defined in components. Maybe you can consider moving the functions from the component to Global Definitions.
For an interpolation function defined in the Global Definitions I think that model.param().evaluate("int5(12,13)") should work, but I don't think that there's anything similar available for functions defined in components. Maybe you can consider moving the functions from the component to Global Definitions.
Posted: 3 years ago 2021/09/27 8:36 GMT-4
Thanks! I'll give that a try.
-Erik
Thanks! I'll give that a try. -Erik
