adding heat flux as a variable
hello this is urgent question, i m having trouble defining heat flux in terms of an equation here the eqation is as follows here the l2 i have alredy defined. z is just the z axis changing and q_0 would also be constant. this is for heat tranfers in fluids. for a stionary study
1 Reply Last Post 2021/12/10 4:49 GMT-5
Magnus Ringh COMSOL Employee
Posted: 2 years ago 2021/12/10 4:49 GMT-5
Hi Divya,
This is straightforward in COMSOL Multiphysics. Just type it in as
q_0*(1+2*z/I2)*(1-2*z/I2)
For the expression's unit to be compatible with a heat flux, q_0 should have the SI unit W/m^2 or similar, and I2 should have the SI unit meter or similar.
Magnus
Hi Divya, This is straightforward in COMSOL Multiphysics. Just type it in as `q_0*(1+2*z/I2)*(1-2*z/I2)` For the expression's unit to be compatible with a heat flux, `q_0` should have the SI unit W/m^2 or similar, and `I2` should have the SI unit meter or similar. Best regards, Magnus
